Categories News
How Call Of Duty Cold War Is Challenging And Scary Both At The Same Time?
Most of the gamers have heard that call of duty is simply a game of shooting but it is not the case in call of duty Cold War. If you want to know about how scary the scheme can get then you need to stay till the end of this article and also you can consider Cold War hacks. It will be going to help you a lot in stink till the end of this game in becoming a professional as hack will make you and beatable and no one can beat you until an unless you want them to
Cold War it’s completely shooting game but there is a mode which is called as zombie mode and that is absolutely scary because in that you will get zombies or many other scary creatures to fight with.That is the thing which makes this game scariest as well as challenging because you need to pay attention on all of the zombies and kill them with the help of the special weapons that will be provided to you at every level.
If you’re new than you first need to complete the campaign mode only then you will get to play zombie mode. In the campaign mode you need to follow the story make sure to complete all the missions right away in the game.
how can we unlock zombie mode?
If you wish to play zombie mode but you found it locked in the game then you first need to focus on the campaign mode. You have to tap on the campaign mode and finish it first with hundred percent success rate. In the campaign mode you have to follow the mission and your teammates because these two are the only things which will help in achieving success.
After completing the campaign mode with hundred percent success rate you will find out that zombie mode is now on load and you can try it. It is unlocked which means you can play it any time you want to without any issue at all. In the zombie mode you will find different weird creatures that you need to kill with the help of the weapons.
Carry as much ammunition as you can
If you want to survive till the end of the zombie more then the best advice is to carry as much ammunition as you can because there will be an unstoppable wave coming towards you that you need to eliminate. It might be not an easy task for you to do which is why it is said that more guns  means more survival.
Bottom lines
Call of duty is the best game in terms of shooting because it provides you with the immense feel and also you will come to notice that there are so many new things edit in this cold war version. If you are playing a campaign more than you won’t get a choice to choose anyone so this is the limitation you to follow.
