The American Board of Obstetrics & Gynecology (ABOG) examines and certifies nearly 1,700 obstetrician-gynecologists and subspecialists in maternal-fetal medicine, reproductive endocrinology/ infertility, gynecologic oncology, female pelvic medicine and plastic surgery annually. Additionally, quite 5,000 physicians are examined annually for the maintenance of certification.
You’ll be expected to demonstrate the talents necessary to use the acceptable knowledge to the management of clinical problems.
These skills include:
● Obtaining needed information
● Interpretation and use of knowledge obtained
● Selecting, instituting, and implementing appropriate care
● Management of complications
● Follow-up and continuing care
The abog qualifying exam consists of multiple-choice questions that cover approximately 30% obstetrics, 30% gynecology, 30% office practice and women’s health, and 10% cross-content. The amount of questions varies annually.
Many of the abog qualifying exam questions are constructed to be thought to impress and problem-solving. For many questions, all possible answers could also be plausible, but just one answer is the most correct. The exam takes approximately 3 hours and 45 minutes. In 2019, the entire pass rate was 86% and therefore, the pass rate for first-time test takers was 91%.
Before scheduling an examination appointment, you want to have already:
● Been approved for an ABOG qualifying examination;
● Been notified of your eligibility to take a seat for the examination;
● Q banks are the simplest thanks to reviewing for the written exam.
They’re effective and if you employ the proper one, it’ll cover all the topics you would like to understand.
● One of the favorite studying tips is to work out your “unknown unknowns.” Simply put, this suggests you ought to determine what you don’t know. Here’s the way to do this:
● Answer an issue from a Q bank If you answer incorrectly, read the reason
● Take notes about why the right answer is correct, and confirm to require notes on anything within the explanation that you simply didn’t already know
If you are doing this for each question you answer incorrectly, and if you often review your notes and add information to topics as you are doing more questions, you’ll eventually determine your unknown unknowns. In return, you’ll uncover most of your blind spots that question on the board exam can ask about.
Results of the exam are typically revealed in September of an equivalent year. If you pass, that’s great, and you began the method for your oral. If you fail, all isn’t lost because you’ll get more chances. There are some stipulations, however. If you fail the written exam five consecutive times, you’ll get to complete additional education before becoming eligible to take a seat for the written exam again.
Taking your ABOG Qualifying Exam, there’s such a lot at stake. Taking time to spot your unknown unknowns won’t only assist you to steel oneself against and excel on your exam, but it’ll also assist you to expand your core knowledge. Then, on test day, use the simple techniques you learned here to increase your chances of getting an issue correct.
