Dental implants are considered an effective and popular method for replacing one or more missing teeth. In the U.S., dentists place over 5 million implants.
If you are interested in dental implants Brooklyn but unsure if they are right for you, you are in the right place. Keep reading to learn some of the top benefits of this popular tooth replacement option to make an informed decision on whether you should invest in them.
Versatility
Full dentures, partial dentures, and bridges are all limited regarding how many teeth they can replace. Because of this, treatment options may be limited based on the number of teeth you are missing. With implants, though, you have a more versatile treatment option. An implant can be fitted with a crown to replace just one tooth, a partial denture or bridge for replacing multiple teeth, or even full dentures to replace all your teeth. This allows you to have a customized treatment plan based on your specific needs.
Comfort
The implants are embedded right into your jawbone. While this requires surgery, it is a better option since it simulates your tooth’s root and provides the prosthetic with increased support and strength. While you are healing from your implants’ placement, the bone will begin to grow around the titanium rod put into your jaw, keeping it firmly in place. This increased stability helps the implants feel more like your natural teeth, and most people forget they are even there. Other options for replacing teeth don’t provide this, and they do not feel as natural or secure as implants do.
Talking
Your teeth play a crucial role in helping make specific sounds. If you don’t have a few important teeth at the front of your mouth, it may significantly impact your speech. Also, loose dentures may slip or slide while you speak, causing you to lisp or slur your words. This is often embarrassing and distracting because you have to constantly worry about whether your dentures will slip or what your voice is going to sound like.
With implants, you will see all the benefits mentioned here and more. Be sure to keep this in mind when you are trying to find viable tooth replacement options. Being informed will help you decide what you need to do and if implants are the best option for your tooth loss issues. Your dentist can also help you decide what the best course of action is.
