A dental emergency is one of those unexpected turns that life throws at you. We Indianapolis residents love to smile, so if you suddenly get a toothache, break a tooth, or have gums that will not stop bleeding, you might be thinking, “Do I need an emergency dentist?”
There is no right answer. But there are times when getting dental care right away is very important. Here are some warning signs that you should not ignore and why you might want to see an emergency dentist in Indianapolis right away.
Why getting dental care right away is important.
Dental problems can happen quickly and cause a lot of pain and discomfort. If you do not pay attention to these signs, you could end up with bigger problems like infections, lasting damage, or losing your teeth. Not only is it important to get dental care right away to ease pain, but it is also good for your long-term oral health.
Keep an eye out for these signs.
- Severe toothache
A rapid, severe toothache is one of the most common signs that you might need to see a dentist right away. Tooth pain that would not go away or is very bad could be a sign of an infection, an abscess, or a deep hole. If you ignore this pain, it could get worse, like the infection spreading to nearby tissues or even into your bloodstream.
- Broken tooth
If your tooth is broken or chipped, you should get it fixed right away, especially if it hurts. There is a chance that the nerves and blood vessels in the pulp have been damaged, which lets bacteria in and causes pain. A root canal treatment is needed to remove the damaged pulp, which is then cleaned and dried. After a gutta-percha filling is put in, a special dental cap is put over the tooth to protect it from more damage.
If the fracture goes through the jawline, the tooth has to be taken out. The pain and swelling will go away after that. A dental implant will be used to replace the missing tooth.
- Bleeding gums
Mild bleeding when you brush or floss your teeth is normal, but gums that bleed a lot or all the time are a sign that something is wrong. It could mean you have gum disease, suffered an injury, or other problems that need quick care. An emergency dentist can look at the problem and tell you what solution will work best.
These are just some of the many signs that may point toward the need for an emergency dentist. If you notice any changes or issues with your oral health, consult a dentist immediately!
