Methamphetamine, or meth, is a very harmful drug. There are many adverse effects from taking this drug, including:
- Anxiety and paranoia
- Confusion
- Insomnia
- Mood swings
- Violent behavior
- Non-healing sores on the face
- Stained, broken, or rotten teeth
- Feeling of insects crawling under the skin
- Impaired judgment
- Increased body temperature to dangerous levels
While some may think taking meth is harmless, it is terrible for your body and can cause permanent damage. Things like rotting teeth can cause permanent damage that can never be repaired by your body, even after stopping the drug.
Are You Addicted to Meth?
Do you or someone you know have a meth addiction? Taking meth even one time is dangerous because it is very addictive. Whether you smoke, snort, or inject meth, the addiction potential is high. When you use the drug, it stimulates the brain to release dopamine, which will make you feel good. That good feeling makes you want to retake the drug, and each time you take it, the desire to use it again increases. As your brain and body adapt to the drug, you will need more and more of it to reach the same high. As this cycle continues, your body will become dependent on it, and you are likely to develop a meth addiction.
There are some signs to look for to spot a methamphetamine addiction.
- Dramatic weight loss
- Financial problems
- Red and irritated sores on the face
- Unable to stop using, even though the drug negatively impacts your life
If you try to stop using meth on your own, you will experience withdrawal symptoms. These symptoms include:
- Nausea and fatigue
- Paranoia and anxiety
- Hallucinations
- Insomnia
- Excessive sweatiness
- Severe depression
- Suicidal thoughts
- Anger or agitation
Is Meth Addiction Recovery Possible?
Meth addiction is a powerful problem that affects you physically and emotionally. An addiction entails such a strong urge to use the drug that it is difficult, if not possible, to break on your own. However, recovery is possible with the help of supportive friends and family and professional treatment. A drug addiction treatment center will increase your chance of success dramatically. While using a treatment center away from friends and family can sometimes make recovery hard, it can also help with the healing process. Using a treatment center in another city or state may help you to reach success and get your life back. Click here to visit the website.
