Categories Home
What is Elastomeric Paint?
The question – what is elastomeric paint – is somehow common among those who want the paint to form a barrier against moisture. Therefore, people should consider this paint. They made the elastomeric paint specifically as a coating to protect masonry surfaces. It is similar to other paints in that they apply it in liquid form, and it hardens into a watertight, flexible covering. While this paint can return to its original form, it can also stretch without damage when experts handle it correctly.
Advantages of Using Elastomeric Paint
People can expect to get a secure coating on the surface they paint as one of the reasons to use elastomeric paint. It will be impossible for moisture to penetrate the walls since the coating has created a barrier. This situation can work well on surfaces like metal, bricks, roofs, poured concrete, stucco, and masonry.
Protection
Most times, heavy rains with the wind can damage paint coatings. However, this is not the case with elastomeric paint since it is designed to weather any storm than any other conventional pants.
Density
Elastomeric paint tends to be thicker than any regular paint, and people will always see this in the result.
Bendable
They used stretchy materials to make elastomeric paint. With this, it aligns with whatever structure anyone places them on. As such, the changes connected to climate changes can make it shift with a roof or wall.
Long-Lasting
Elastomeric paint’s strong makeup gives it much more longevity than any traditional paint. It can even last more than ten years when people apply it correctly.
With all these benefits, people may not necessarily need to use elastomeric paint when painting their homes, and some of these cases are:
  • The regular exterior house paint may work when people’s homes have an existing quality coating, and the paint job is in perfect condition.
  • Elastomeric paint tends to be a high build paint. Therefore, it can pull away from the stucco if people add an elastomeric coating on multiple coats of paint on their stucco since it is too heavy.
  • People can also get perfect results at a lower price by using a double coat of quality paint and masonry primer if they are not concerned with waterproofing their stucco.
Specific Drawbacks
People can face some drawbacks when using elastomeric paint. One of these disadvantages is that it is too expensive. Though it will cover much more effectively, buyers may have to part with more than 50 percent of the regular paints. In addition, elastomeric paint can be more difficult to work with since it is quite different from standard paints. Finally, users can also get unwanted lumps in their finish if not applied correctly.
The Best Paint for Stucco
Opinions differ regarding the best paints to use on stucco. However, several paints can work well on it. The three main paint types many experts recommend for stucco are:
  • Elastomeric paint
  • Masonry paint
  • Acrylic paint
People will need paint that will contract and expand for stucco. Such paint also needs to be dirt and mildew resistant, and extremely durable. It must also have ideal elasticity and be waterproof to help resist cracking.
