Eyelash Extensions: Retention Problems?
Eyelash extension retention can be one of the most common problems in the industry with your lashes. It often leads to a series of unhappy clients and difficulty amongst staff. In order to overcome these issues, you can take a look at techniques as well as the products that you’re purchasing. Here are some tips on how to improve retention problems.
Improving Adhesive
There’s different guidelines on how to use adhesive, curing times and a series of adhesives that you can try out before finding one that performs the best. We recommend working with adhesives with different temperature and humidity levels so that you can ensure good retention throughout the entire year. Make sure that you’re doing your research, trying at adhesives over a long-term trial and using full directions.
Try Bonding Agents
Cyanoacrylate is a bonding agent that requires moisture in order to cure and your environmental conditions may be affecting your retention. A thermo hydro meter and humidifier are excellent ways to alter moisture levels in your studio and improve retention rates. Changing the humidity in your environment could mean faster bonding and better retention.
Retraining
Different training schools provide a number of techniques that lash artists can use when applying lash extensions. There’s no right or wrong way but sometimes it helps to confer with other lash artists or retrain to find a method that is easier to obtain better retention.
Speak To Your Clients First
It’s possible that you will come across a client that has ongoing issues with retention. There is no need to panic if a person has regularly had problems with adhesives or retention rates. It may just mean that you will have to use a primer or a different process to help that individual client. Having this pre interview can help you to work with each individual for better results.
Consider some of these top ideas and more if you are interested in improving retention rates over time.
This post was written by Natali Roshau. Natali has over 10 years of experience as a lash artist and is the owner of https://lashaddictstudio.com/. Lash Addict studio offers the best quality eyelash extensions in Saint Petersburg. In addition to being a lash artist, she also offers eyelash training certifying girls across the nation!
