Categories Health
Choosing The Best Vape Juice For You
When it comes to selecting which vape juice you will try when vaping for the first time, it can be daunting with so many choices available. There is a myriad of flavours available, and you also need to consider things like the PG and VG ratio, so there is a lot to take in when you are a newbie. If you are new to the world of vaping and looking to start to help you quit smoking, you will need to take your time and not rush into making your decision. If you make the wrong one, it could put your off vaping for life and reside you to a life of smoking. Below are some factors to consider when selecting the vape juice that can help you make the correct choice and start yourself on the road to a smoke-free life.
Which Vaping Device Do You Have?
When you look at the different vape juices you can buy, you will notice that they all have a PG/VG ratio. PG stands for Propylene Glycol and VG for Vegetable Glycerine, which are the primary ingredients of vape juice. Most vape devices can use a 50/50 ratio of VG and PG, but if you have a more advanced device that can vape at higher temperatures, you may want to go for a higher VG ratio which will help you blow more enormous clouds of vape. If you have an e-liquid with a higher PG ratio, this will give you a bigger hit on your throat, like smoking cigarettes. Ensure that the vape juice you purchase is suitable for your device, and you can ask your local vape store if you are unsure.
How Much Nicotine Do You Need In Your Vape Juice?
You will also need to consider the strength of the vape juice you purchase to ensure that it will satisfy your cravings when you quit smoking and take up vaping. The nicotine strength can vary, and many e-liquids are available in 0mg, 3mg, 6mg, 12mg, 18mg, and 22mg formulas. If you were a heavy smoker, you would want to start with the stronger vape juices, and you can then slowly reduce the strength until you reach zero. You can also consider using salt nicotine e-liquid, which many heavy smokers prefer and can help to satisfy nicotine cravings. Once you are at the zero-nicotine level, you can continue vaping without nicotine if you like the taste or stop for good and enjoy being smoke-free.
A World Of Vape Juice Flavours
There are so many vape juice flavours available that, without a doubt, there is a suitable one for you that you can choose. You can select from tobacco flavours, fruit flavours, dessert flavours, and much more besides. Most flavours are available in various nicotine strengths, including nicotine-free, and as they are relatively inexpensive, you can keep trying ones until you find your preferred taste. With a bit of patience and experimentation, you can find the perfect tasting vape juice that will give you the best chance of successfully quitting smoking for good.
